Hi
I'm about to refit my kitchen and am looking in to some lighting for it. At the moment I quite fancy fitting colour changing RGB LED tape both under the wall units and around the plinth. I'd like this to all be run from one remote control (something like ) but I am not sure how it will all need to be connected together to achieve what I am after.
At plinth level, there will be a run of just under 3 metres, then a gap of 90cm (range cooker) then a further run of about 2m. For the wall cabinets it's roughly 80cm, then a big gap (2 metres ish - window) then a 60cm unit, 90cm gap (extractor) then another 2m run of units. Basically a U shaped kitchen with a window in the first leg and a big cooker and hood in the middle bit.
Can anyone help with advising me what I need to buy in order to make this work? It will be fitted by a pro but I am getting a bit lost with the various connectors, receivers, controllers, transformers and power supplies so am struggling to work out of it will even be affordable! Also any recommendations of the best place to order from?
Oh, one last question....is it possible/safe to fit this to the underside of the extractor so I have the same coloured lighting over the cooker? I would probably still need a gap in the LEDs as the bottom of the extractor will be higher than the bottom of the surrounding cupboards.
Thanks in advance
Thanks in advance
