I learnt all the devices and everything worked, I did a movement test with the PIRs in the rooms but not attached to the walls and they all triggered the alarm, then I put one PIR up on the wall and it was dead. It would not detect any movement (or rather heat!) even if I waved right next to it. It replaced a wired PIR in its place which worked fine.
I have tried relearning the PIR but again nothing happens. As soon as I remove the lid of the PIRs the alarm goes into tamper so I know the PIRs are physically connected.
Any ideas what is up? I wonder if I have accidentally touched the lens when I was screwing the board back into the base plate or is there something else I am doing wrong?
I have installed several wired PIRs in the past without any issues.
EDIT just realised I put this in the wrong section, I am shattered!. Just asked a mod to move it.
