Ridge Beam question
6 Mar 2014
Birmingham
I am just sorting out the pitched roof for my new garage but I am unsure of how the ridge beam should interface with the blockwork of the gable ends. Does the ridge beam simply sit on the blockwork at each end or should I use a bracket to firmly secure it to the brickwork? The gable ends are single skin blockwork.
Probably a silly question but I cant find any details for this on the internet.
If anyone has any pics that would help too.
Thank you in advance for your help.
Anthony
Usually there is a concrete padstone under the beam at each bearing.
But if it is only a short span and not heavily-loaded, you might be OK with an engineering brick.
the garage is 6.5m x 6m so the roof will be fairly big and heavy. I guess I should use a concrete padstone to be sure? Will the ridge beam just rest loose on the top or does it need to be secured to the blockwork somehow?
Anthony
Just rest it on the top, but ensure that the rafters are tied down to the perimeter walls.
