After 25 years the ridge tiles on my roof are quite loose in places. They are a grey cement/concrete type. Some can be just picked up as the mortar no longer ‘sticks’ them on. The mortar looks like lime and is quite soft/eroded in places but none falls out in chunks even if I do lift a tile. They are only mortared at their ends and not all along the roof/ridge tile interface. Is that normal?
I have scaffolding up for another job and only have a very short time left before it comes down, so I don’t really have time to remortar the whole run, nor the skill to do it well. So instead what about using a bitumen sealer paint to fill the mortared gaps between the ridge tiles. This will waterproof the mortar (limiting further erosion), stick the tiles to the mortar and stick the tiles to the roof tiles at their corners only. Also retains flexibility if not applied too thickly. I have some Aquaprufe water based emulsion bitumen I could use. It’s quite thin so will penetrate the joints well. Any drawback? How flexible does the joint need to be to allow for heat expansion, etc?
I also have an unused chimney with metal flue pipe whose mortar with cement on top crown is completely broken up. Can I just use a premix concrete to replace this? I have read that 2:1 cement and pea gravel mix or 1:4 cement and sand is recommended so this premix is pretty close. I am not casting an overhanging cap. And what about bitumening over that too to limit water ingress? Not suitable for a working chimney.
