Hi all,
I have just finished the mist coat in my house, and I have one 8 meter wall that was plastered in two halves. I thought that I had already filled and sanded the gaps in the join properly, but in bright sunlight there are two clear shadows of about 2-3 cm wide running up the wall.
My approach to sort them out is going to be to put a light coat of PVA into the area, and when tacky use a fairly wet mix of easifill with my long finishing trowel to fill the depression. Once dry I would put another coat of easifill and then lightly sand it down flat.
Is this the right approach, is there anything else that I should be doing instead?
Thx,
Jon
Thx,
Jon
