Riello 40 Oil Leak
19 Apr 2008
Help!
We have an oil leak from a Riello 40 Oil Burner fitted to a Geminox FX25. With the red cover removed you can clearly see a drip of oil from the right side of the burner. The plate covering the air intake is covered in oil. It’s about 13 years old and other than the oil leak it is working fine.
Any ideas? Is this a common problem that can be repaired or is it a replacement job?
Judging by the oil residue around the boiler this drip is wasting a huge amount of oil.
Any help appreciated.
Get an oil man out, the best thing i use to seal oil is ROCOL oil seal. But dont do it unless your oftec registerd
