Hi everyone,
I have a Grant Vortex external combi about ten years old which has caused no end of problems since installation.
I've replaced quite a few parts myself over the years but I'm currently facing a problem that I'm hoping somebody will have faced and know what is causing it.
The Riello burner motor won't run and this is what I've done so far:
1. Removed the burner so its in front of the boiler but still connected to electricity and oil.
2. Taken the end cap off the oil pump to check it spins. It spins fine.
3. With the oil pump off, turned the shaft on the motor which also spins freely.
I've tried switching it on with the oil pump off and watched the motor shaft that the oil pump slots onto. It slowly turns maybe 1/8 of a turn then stops. It'll do this most times if I turn it off, wait, then turn it on again.
I thought maybe the capacitor wasn't working so replaced it with a new one but exactly the same thing happens.
Has anyone faced this problem and can please help pinpoint what is causing it?
