HI,
[EDITED]
I have a Riello RDB Blu 2.2 burner fitted to my Grant boiler, which was installed in 2018. Over the last few weeks the boiler has failed to fire up when heating/HW is called. This has happened before and I learnt that the problem is solved by taking out the photocell (part number 30008646) and cleaning; this is what I have been doing this time. However, it is not ideal, so I have ordered a replacement part. The burner has a digital control box. Edit: for information, the photocell appears very clean on removal.
However, the new part (number 20181375) looks very different. The most obvious difference is that it is at least a couple of centimetres longer. Apparently, the sensors were completely updated to comply with directives 2002/95/CE RoHs, and 2011/65/CE RoHs2. I quote the information leaflet supplied with the replacement part: The flame sensor with semiconductor technology replaces completely the CdS cadmium oxide sensors or photocells according to [the above directives]. the photocell was replaced a couple of years ago during a service, because of the same problem.
I would like to know if anyone else here has replaced this part, and if so could confirm that the replacement I have received is correct.
[EDITED]
