Riello RDB intermittently cutting out
9 May 2019
Hi, I would be grateful for any help or advice. I have an Riello RDB which intermittently cuts out and stops working. Sometimes it can go for a few days without problem, sometimes just a couple of hours. It restarts by pressing the reset button successfully on each occasion.
It has been serviced recently and had a replacement nozzle fitted.
I have done some preliminary checks as recommended by searching these forums and the Riello website. The white wire returns 55.4 volts and the solenoid resistance is 98.3 ohms. The voltage from the motor seems marginally high but would this be causing the problem? Any suggestions or advise would be much appreciated thank you.
Try changing the solenoid coil it sounds like it's starting to play up also get the pump pressure checked.Bob
