Hi there,
I have just bought a new house that has a Baxi 105e combi boiler and was serviced every year by British gas. We got the property in September but didn't move till mid November, and didn't use the boiler "full blow" till then. I only switched it on and allowed it to run a couple of hours the central heating when it started to get cold and freeze during the night around the end of October in order not to have the pipes frozen. The boiler seems to work beautifully, but the problem is that the pressure was low and I raised it via the loop circuit to 0.5 bar. Fine there, but when I have the central heating on, it raises between 2.4 and 3.2 bar, depending if it is firing or not. Obviously, if I bleed the radiators meanwhile working, and set a comfortable pressure of 2.3, the pressure drops to 0 when cold. It doesn't prevent it to work correctly when the timer switches it on or the hot water is needed, and doesn't misfire, but I'm worried about the future and if letting it go to so high pressure will damage any part, and equally, letting it go so low pressure when cold will do de same. Any suggestions?. Shall I let it be with a 0.5 bar when cold and with 3.2 when the CH fires or shall I let it work with below 2.5 and allow it to go to 0 when cold?
Sorry for such a long one, and Cheers.
