ok guys heres the problem. Recently moved some sockets higher up the wall on my upstairs ring as i am having bigger skirting fitted. I extended the wiring to the sockets by crimping, using a good ratcet crimper and the correct crimps aswell. All went well till i went to the CU to test for Ring continuity and didnt get a continuous result. So, checked if each socket was working in turn, and every socket works fine. So, is there a break somewhere in the ring between sockets?
