Ring lighting circuit wiring confusion
3 Feb 2012
Birmingham
Dear All
I'm having a bit of a problem wiring a light in one bedroom. The light was flickering and if i tapped it, it would work ok. However last night it started making a crackling noise so decided to try and fix it.
After opening it, i took out the light and neutral wire off the lampholder, and noticed two neutral/black wires twisted together and going into the "loop" fitting on the holder, which was lose. So i tightened it back up. However i could not remember in which port the blue and brown lamp holder wires went into. I tried different combinations but no luck. There were also 3 red wires twisted together in one connector.
At one point, i had the lamp on when the switch was in the on AND off position.
I've tested the black and red wires which are coming off the main ring, and they were both showing as 240 on the multimeter. However when i try for a voltage on the brown and blue lampholder connector, i get no voltage.
I've taken a picture of how its connected up. Can someone please advise where the wires should go?
Many thanks
And that's all you removed from the rose? The 2 wires going to the lampholder?
and noticed two neutral/black wires twisted together and going into the "loop" fitting on the holder, which was lose...There were also 3 red wires twisted together in one connector.
Those were the only other wires there?
You didn't change anything?
What else is connected to the terminals you've connected the lampholder wires to?
It might be helpful if you posted it here then.
Yes:
//www.diynot.com/wiki/electrics:lighting
