Looking for some help I have with a ring main. The 32A breaker serving this circuit tripped and wouldn't reset so by a process of elimination, I established (I think) that there is an issue with a cable running between two adjacent sockets (around 2m apart). If the live from either end of this cable is in circuit then the breaker trips - removed and all appears ok (although with the ends removed the breaker did trip once a few hours later but did then reset). What is baffling me is the fact that I can find no shorts (to neutral, earth) on the cable so don't know why it causes the breaker to trip (unfortunately the cable runs under a wooden floor so I can't see what may be going on). Any ideas?
