I'm replacing a single socket in the Dining Room with a double socket - sounds easy? When I unscrewed the existing socket (having isolated the ring) I noticed that one of the Neutral wires was loose - but thought nothing of it. I disconnected the socket, removed the single box, chased out the wall for a double box, fixed the box, wired up a new double socket, reset the circuit breaker - pop! The circuit breaker would not reset - just kept tripping. I disconnected the new socket (leaving wires safe) and reset the circuit breaker - no problems. Tried wiring up the socket again - kept tripping. I disconnected the socket and simply wired the cables together using terminal block, just to connect the ring - circuit breaker kept tripping.
So now I'm stuck. All the sockets work fine on this circuit as long as I don't connect the offending socket.
Any thoughts?
Cheers,
R.
Any thoughts?
Cheers,
R.
