Hey all,
As subject says i suspect i have rising damp??....
It's manly on the party walls, which i find a bit strange but hey...
I have dug away a bit of the plaster at the bottom of one of the walls, to reveal what looks like an old skool tanking membrane... looks like a roofing felt material corrigated type stuff??
The damp is typically showing just over a metre up the walls (so suspect that is where they stopped with previous tanking), and it is really not pretty... apart from where there have been fixings drilled into the walls at a lower level in the past where we are getting the odd spot of damp...
So... I have had two companys come in and quote for reapair and a damp surveyor, and they have all suggested tanking the walls with damp proof membrane straight over existing palster, then dot and dabbing fresh plaster board over that as they suspect it is mainly salts?? But does get really wet...
Does anyone have experience with this problem and can give any suggestions as to the best way forward?
We are on a very tight budget, so am thinking of tackling this myself, i am very practical and have succesfully tackled many home improvement projects in the past, and am an electrician so no stranger to building projects and the like
I was considering injecting a dpc, but just can't make my mind up?
If i tank... will wall not just stay damp behind and fester? (do i need to batten to leave air gap or?
Will dpc injection be best? (is it ok to do from inside? was thinking in the first showing mortar line?)
They are only single skin brick walls, house is mid terraced approx 100yrs old.
Any help would be greatly appreciated, as i really need to get on top of this unsightly damp once and for all
Thanks in advance
Keiran
Thanks in advance
Keiran
