In a strange moment I bought these Piedra de rio mosaic type mats to make a stripe round the room. Nominally they're 33 x 8cm, each stone is sliced about 6mm thick , and they're natural shapes, between 2 and 5 cm across. Marble, stripey limestone, etc.
That means there will be a lot of grout showing. The stones aren't cut to width, so the width of the stripe varies.. So much that I'm going to have to nibble or cut the odd protruding edge. Each stone has an uneven edge, sloping etc, and they vary in thickness a bit too.
Anyone got any tips on laying them?
I assume I just use "wide" type grout, and a wet sponge to smooth it between the stones. The gaps vary from 0, to 1 cm or a bit more.
4 bar shower pump so they'll have to hang on tight.
Perhaps I'd be better off just tiling the walls plain white and making a vertical stripe of these stones a foot or so wide!
