Hi.
Please help with a difference of opinion on a bath front panel between the local trusted bathroom trade supply shop and the plumber who will do a simple but attractive bathroom refit in a rented property – I have good respectful tenants, nonetheless it should be a practical and robust installation.
I would do this job myself but don’t have the time so have found a good recommended plumber with whom I have agreed on most things. He is happy to fit what I supply but obviously has his view on things, mostly based on good/bad experience. The guy in the shop also has his favourites – perhaps based on best profit margins?
In a rented place we are all agreed to not fit a flimsy 2mm/3mm normal front bath panel as it probably won’t last very long. However, the shop recommends fitting an MDF panel - I had my doubts but was told they are fine – plastic foil covered panel – a Roper Rhodes Helios 1700mm Gloss White Wooden 12mm. Best price £40 – the shop say they are robust and waterproof and they never have any returns. The plumber says he has had failed ones after just months, so to be extra sure he says to consider fitting the Ideal Standard Uniline White Acrylic reinforced Front Panel 1700mm. Trouble is that retails at over £100, best price from the shop is £83 – a lot of money.
I went back to the shop and the guy there took exception to any criticism of the MDF panel! However, on talking a bit more he revealed that it will almost certainly need to be cut and drilled to fit it - but that it should be fine if sealed with PVA ?? I see the plumber’s point and that once broken, the plastic foil seal reveals the MDF fibre inside, and we all know how easily water finds absorbent materials, like blotting paper. And PVA or silicone etc?? It seems flawed from the start.
I don’t know? Any ideas or experience of these please, or any alternatives? I even wonder if I should fit a normal £25 panel and if it gets broken to then just replace it – at least it won’t swell from water absorption!?
I don’t mind spending the money on the Uniline if that’s the one but would like a view from you on it first. Any help much appreciated.
Thanks,
Sproutsdad
Thanks,
Sproutsdad
