Roca basin mixer tap
6 Dec 2009
Merseyside
Any idea where I might obtain a 40mm (approx) spanner to remove a plastic locking ring on a Roca mixer tap. I'm assuming this retains the cartridge that I want to check out. Original issue is no water coming through tap, hot or cold, since I switched mains supply off / on. The tap is a direct feed off the mains so I doubt it's an air lock, more likely some debris or force of mains pushing air out has disturbed something. sibly debris? All other taps are ok.
I've been to a couple of merchants but no joy. Also spoke to Roca but they don't suppy tools or have any suggestions! Its not a hex nut.
