I need to extend an existing 110mm combined sewer pipe, turning it at right angles around the corner of my house in order to pick up the inputs from a new bathroom.
Currently the sewer starts at the rainwater gulley trap at the corner of the house, then flows about 2 metres to inspection chamber (A) at the point where an existing WC drain is connected.
Ideally I would effectively replace the rainwater gulley with a new right-angle inspection chamber (B), and extend the sewer pipe upstream of the chamber to collect the new bathroom discharges. But then how should I re-connect the rainwater drain (a separate soakaway is not possible). I have seen various inspection chambers for a right-angled bend, some with additional (usually higher) inlets for extra pipes, but I cannot find any chamber where the additional inlet lies halfway round the right angle!
I could easily connect in the rainwater somewhere between the inspection chambers (A) & (B), but would this need another inspection chamber (making 3 within 2 metres) to allow rodding access? Maybe a replacement gulley with removable baffle would be sufficient for this purpose.
In a similar way, the bath and basin outlets from the new bathroom will come into the sewer between inspection chamber (B) and another new Inspection chamber (C) to which the new WC will be connected. Is it OK for these bath and basin drains to connect straight into the sewer (maybe via a boss on the pipe crown) without any provision for rodding.
I should say that Building Control have passed our plans, and the inspector made no negative comments on our somewhat uncertain drainage plans when he visited the site. He did however say the existing SVP linked to inspection chamber (A) would provide sufficient venting for the whole extended sewer.
I would be grateful for any useful thoughts or links to relevant guidance
John
John
