Roller Garage Door Corrosion Problem!
25 Mar 2004
Sussex
I have a Double gargage and had a Insulated Aluminium roller door fitted 3 years ago and is now very badly corroded and causing the paint to flake off everywhere.
It was only guaranteed for 2 years so cant do anything about the warranty so I am going to have to replace the slats/curtain.
I live quite near the sea (200m) so really need something that would not corrode. I know you can get UPVC roller doors but I have been told these break very easily especially if its a wide expanse like my 4.3m double garage.
I cant have a Up and Over door as I do not have the height.
Any ideas anyone??????
By corrosion do you mean it has developed holes in the aluminium or has it got a dull, flat finish on the exposed areas?
If it is just mildly corroded with a few pit marks/holes these could possibly be repaired with car body filler and rubbed down smooth. Then apply a sealer to prevent moisture ingress.
As you live near the sea there will be a lot of salts in the air. It may be possible to give the whole door a few coats of clear Yacht varnish and then a light rub down with fine glass paper before painting with a suitable paint finish such as an enamel based paint.
