Roller roller roller.........
1 Apr 2004
Please could you advise on the best techniques, with as roller and emulsion. (short pile ici dec)
Do you cut in one wall at a time then roller, I take it cutting in means the corners and top and bottom?
What size brush for this? and how much in size wize do you cut in, say at the top of a wall near the ceiling 1" 2"???
Also I plan to roller up and down. what is the best method when you get to the top? turn the roller? or use a smaller one?
Many thanks
Hard one to answer, cos every surface has different porousity percentages resulting in answering your question a million times over. But to keep it short best thing is to do is cut & roll one wall at a time.
ok I understand.....1 wall at a time, but what size brush do most use, and how many inches do you cut at the top......... Si I take it you do turn the roller?
I saw a post from Zampa saying turn it at the bottom.......same at the top?
Darren
Every person has there own preference. I use an small 2 inch brush for cutting as this allows for roller effect to be more seen. Also i roll a wall by spreading emulsion first, then roll up and down in order not to cause criss-crossing............................
