Hi;
I am having my roof re-tiled and have some questions / concerns, some of which have been pointed out to me by an ex roofer (retired) who live nearby. I would like some independent advice on before I speak to the roofer again.
I originally ask for facia boards to be replaced but due to cross wires they are being capped, whilst this is fine it means that some brickwork under (top 2 -3 courses) the facias that should have been re-pointed has now been missed.
Here is a pic of some of the brickwork before it was covered:
This has now been covered with a facia / soffit without being re-pointed, as seen in the pic below. The missing mortar is just visible where the facia butts up against the wall.
Also the facia on the rear of the property is rotten on top along its length and this was capped as is. After pointing this out part of it has now been replaced with what looks like untreated pine timber.
I was originally told that they didn't replace the facia because only the top 20mm was damaged. Once it was removed at my request (albeit only partially) the true extent was noted.
An area where a flat roof has been left but the rotted area treated with hardener. I would have preferred replacement but was advised that removing the felt where it covers the facia was too much of a job.
The quote mentioned treatment of all timbers. This does not appear to have been done and although I have been told twice now that it will they have already batten and insulated under the rafters and will somehow treated later if it hasn't been done??
On the inside of the roof they have fitted Actis Hybrid Silver / Poly insulation which appears to have no air gap in many places - is this OK. On top of this they are fitting 6mm ply 1200 x 2400 sheets. Does it need a vapour barrier between the insulation and the ply, are these thick enough to prevent sagging
Soffits have been fitted but do not butt up against the wall, here is a shot of the soffit under the window. The original eves where angled but the roofer has added a batten (pink) to make the soffit horizontal - is this OK?
This is a terraced house and where it meets the next property instead of knitting in they have cut a straight line and I assume waterproofed underneath. They have not installed a Lead Soaker as some do? Will this cause an issue?
On the inside on the adjoining wall where they removed the roof they have left holes into next doors roof space. Apparently this is unavoidable when replacing a roof. They have not and do not intend to fill the holes in - should they be doing so as part of the work?
When cutting in the hips whilst one side is pretty neat this side is far from it.
Whilst the job is getting done I want to ensure it's up to spec.
Any thoughts
Any thoughts
