roof Insulation
11 Jul 2011
Bradford
within our loft I have used Kingspan (100mm) between the joists but as with kingspan and the inpurities in dimensions of my roof, there are a number (well quite a lot!) of small gaps. I believe foam expanding is suitable to seal these gaps, am I correct? Which type of foam expanding material would be recommended, with it been a cold roof in mind.
Beyond that, should i use a water proof membrane to lie on top of the kingspan/joists and then use foiled back plaster boards or is the latter sufficient to reduce any problems with damp/moisture?
Cheers for your input and thanks.
PS. I truly have got a true hatred for kingspan now. Messy stuff.
100mm foil back kingspan/celotex between rafters + 40mm (min) underdraw.
25-50mm air gap above the rafters.
Foil back plasterboard to ceiling.
Use ex-foam for any gaps or a silicone mastic.
