Roof insulation
3 Mar 2007
Buckinghamshire
I'm looking to insulate my house, which is a 1930's semi. the roof hasn't been felted so the loft space is a tad dirty can i do something about this from inside the loft space which will insulate the house and also stop the dirt coming in i.e a material which can easily be fixed to the rafters ?
many thanks.
Ask in the roofing section although I recall the only real solution is to remove the tiles and underlay it with felt, do not be tempted with the spray on foam adverts they kill your roof.
As a temp measure you could staple trio sheet insulation over the joists as it is thin and flexible and of course insulates too.
Pete
Thanks for reply, will look into that, as i don't really want strip the tiles off and felt if i can avoid it. Thanks again.
