Hi all
Just about to start work on my pitched roof as we are adjusting some pipes under it for an en suite. It’s part of a dormer conversion. When we were looking to check the pipe routes it’s clear that the roof membrane has pretty much disintegrated. As part of doing the en-suite I was planning on replacing this. From what I’ve read I’m supposed to use a breathable membrane and I need to staple this to the rafters then batten over the top of it? Not doing the whole roof, only 2.5 metres worth or so. The existing stuff (non breathable membrane) is ok after that.
Looking online it looks as though there are many different options all with vastly different pricing. Budget is a factor and we are doing the house up to resell. So the question is, which membrane should I go for?
I’ve got loads of tyvek house wrap left over. I’m assuming I can’t use that? It’s a breather membrane so sounds like the same sort of thing?
