failing that the good old method of a piece of paper against the wall and drawing the pitch onto that and getting a protractor to work , a roofer would have a roofing bevel that shows you the angle in degrees on the inside edge
following on from blister. draw a vertical pencil mark on the barge board on the gable end of a roof. using an adjustable bevel, set it to the mark. you can then transfer this angle to any decent chop saw and simply read off the saw bench guide, the degree of cut.
An inclinometer or level with an adjustable bubble will cost about £5, which is nothing in terms of the cost of materials for this job and the time in trying to work it out by other methods
you can buy an angle finder these days witha magnetic base ideal for disadeck systems etc or just plain old traditional roofing, they are around £5 protractor? pencil? paper? all well and good if your boss sends you out to measure a job on friday afternoon and you forget your kit but come on, these ways should be a thing of the past! LOL
