- Joined
- 11 Jul 2023
- Messages
- 5
- Reaction score
- 0
- Country
Hi!
I'm looking to purchase a 1960s semi and the Building Surveyor has come back with a couple of issues regarding the roof. The first is that the roof structure has sagged in one place - see image. The roof is of concrete tile construction and, as far as I'm aware, is original to the property. Is it a case of raising the sagging cross member and bolt bracing / sandwiching it with supporting wood both sides? Or another vertical support towards the middle of the horizontal cross member? Also, would this fall to a chippie or roofer if not a DIY task?
(Image Removed)
The other observation was that the gable end wall hasn't been strapped into the roof. Having searched around the internet on the subject I've seen mention to it not having to be done 'back in the day', but advisable - and or the surveyor covering their backs. The solution to this sounds pretty straight forward, but if it's not essential and has been fine for 60+ years then do I go by the old adage of 'if it's not broke...'.
(Image Removed)
Any advice would be much appreciated.
Thanks,
(Image Removed)
(Image Removed)
Thanks,
