Roof Truss Question?
12 Jan 2008
Glasgow
Whats the best way to check the pitch of the trusses on my existing roof so that when i order the trusses for my extension they are the same pitch?
Or you can measure the height and half the width, from which you can work out the hypotenuse and the angle, or let the truss manufacturers do it.
used the angle finder on my HTC.hope that works,its showing 32 degrees.
Use the HTC to measure a known angle, before you rely on it.
I've got an HTC desire, and used it to measure my Rafters. They came in at 35 degrees.
Smart phones are great, but make sure you understand the callibration. I trusted the phone GPS with Endomondo to measure the distance I ran, training for the London Marathon - and it turned out to be over reading by 10%........... So I hadn't run as far in training as I had thought.
Measure some flat and vertical things with it to see if it gives you 0 and 90 degrees respectively.
Cheers
Gary
The problem with a phone or anything that small, is that you are are only measuring a 100mm section of timber which could be bowed or twisted and could easily be 5 degrees out on the measured part of the rafter
For what it's worth: mark 12" on the top of a level
set the level against the under edge of any common rafter.
measure up to the rafter bottom edge from the 12" mark on the top of the level, say 8".
you now have the unit base and rise, convert in trig.ie 8/12 = 33.75degrees.
You can also, if you have a side elev. view of the roofline from the ground, hold up a level ( eyeballed ) framing square and measure 12" from the roof slope towards the centre to the roof, on 12" measure up, say, 8" and once again you have your unit triangle - the slope/pitch being your hypotenuse.
Both simple methods to use but weird to explain.
