Roof venting
27 Apr 2011
Somerset
Hi guys.
I over-clad the fascia and soffits of my bungalow a few years ago, I am now doing a loft conversion and I need to vent in-between the rafters for building control.
As the asbestos soffits are still in place I obviously cant drill holes for push in vents in the soffit.
Although I have been fitting fascia's and soffits for years (so I could do it myself) I would like to avoid the hassle of stripping the roof back to fit over fascia vents if possible.
A couple of ideas Ive had so far:
1. I'm wondering if somewhere sells a smaller push in vent (70mm would look a bit hideous) that I could fit through the fascia and hide behind the gutter?
Assuming this is doable could it also let water in though?
2. My other idea is external trickle vent covers also hidden behind the gutter with holes drilled through the fascia. This would at least provide protection from any driven rain.
Can anyone recommend any alternatives?
And before anyone says it, Don't say "don't over-clad asbestos lol"
Have you plaster boarded over the rafters yet? If not you could open the flaps on the felt using some small pieces of overflow pipe, then install vented dry ridge system
If the ridge tiles need to come off that may be an option, If not that would be even more work than fitting the over fascia vents.
I will keep it in mind and once the dormers are being built I can decide on that one.
Any other ideas?
The time it takes you to remove the gutter and do all the venting you may as well just push back the first row of tiles and screw over fascia vents along the top of the wood. If it's a detached it won't matter if the tiles are raised an inch. Or is it rosemary tiles pain to take off?
Otherwise just get a 22mm wood bit and drill loads of holes behind the gutter at say 12" spacings. As long as it's behind the gutter it will be dry as a bone but for peace of mind just drill upwards at say 30 degrees so any water will simply run out.
http://www.ebay.co.uk/itm/Stainless...Ceilings_Walls_Roofing_ET&hash=item27f528d9df
Cut the mesh tape down to width and run along the holes. Once the gutter is back on you won't really see the holes or the mesh.
There are several gables and I would have to re-render in the end tiles too also a tricky spot to get to over the conservatory. As I say I could do it but I am pretty well booked up at the moment so I was looking for a faster option
I like it! Hadn't thought of drilling up at an angle. Thanks
As someone in the building section sounds to have a similar problem I thought Id let you know what I went with.
I bought one of these:
http://www.ebay.co.uk/itm/Dade-Dust...Home_Garden_PowerTools_SM&hash=item46316c489f
I used it with the 70mm drill bit to just drill through the plastic then with a short sharp hit from a hammer smashed holes through the old asbestos. Obviously all while wearing a disposable boiler suit, Goggles, an M3 dust mask and a hat.
