Hi all,
a roofing question. Forgive the crappy drawings but i cannot do much better! (The one with the green line is where i suspect we have a lack of air flow)
We have curved ceilings in our bedrooms as the rafters come down through what would be corners where wall meets edge of roof.
We have recently had lots of insulation added, about 400mm now. This concerns me in that where it is stuffed down between the lath and plaster ceiling and the tiles, there cannot be much air flow. Also the membrane is an 80's type (?) looks like a swimming pool cover. Is clearly totally vapour and water proof. Thus there are beads of condensation forming on the inside and probably ending up down near the rafter ends where there is little air flow.
We also have evidence of what a BWPDA inspector calls 'historic' beetle attack.
Am considering the merits/demerits of removing all the mineral wool insulation to encourage air flow, then have loft floor sprayed with thinner layer of foam insulant?
Any thoughts?
Thanks to all.
T
Just realised; I didn't draw any battens. There are battens .... Imagine there are battens!..
Any thoughts?
Thanks to all.
T
