roof wallplate
1 Aug 2006
hi all
can someone tell me if its OK to fix the wall plate on the external wall rather than on the internal block work
am going to have a truss roof and wanted to put the wall plate on the outside wall
is there any reason that the wall plate needs to be on the internal wall
regards
Franky
Internal walls are loadbearing, external are cladding.
It depends on the load, location, kickout force etc.
hi
my external walls are brick work and intenal walls are block work with a 50mm cavity both built off the footings
the reason i ask is because the outside brickwork is level all the way round and who ever built the blockwork did not build it as level as the brick work.
so would be easier to bed the wall plates on the external brickwork than internal blockwork
regards
franky
Static is right .Though my chalet bung. has the plate on the outer skin and exposed rafter feet.....60`s built....Sussex too. Your Building Control officer would tell you ;)
Also is extremely hard to fix holding down straps to an external wall.
