Hi, we had a 55x78cm Velux window fitted by a local roofer over the weekend in our ground floor extension, and I just want to get some opinions on what you think about the job.
Here's a pic of the outside:
And here's a pic of the inside:
It'd be great to get some feedback on the following if possible:
1. He hasn't tiled up to the edge of the flashing gutter, so you can see each piece of the metal flashing on the sides. Is this nothing to worry about, or is there a chance it will leak?
2. Another note on the flashing - the side flashing pokes out at the top, is this wrong?
3. If you look at the 2nd photo, you can see he hasn't doubled up the rafters. Does it matter given its such a small roof? (room is 2.4m x 2.2m)
4. While he was putting the window in he removed one of the joists, because he wanted to move a rafter across slightly. So now I'm thinking a) either we put it back roughly where it was, or b) we consider adding some wall plates and some additional raised joists, directly above the top of the window level so we can raise the ceiling (in the centre of the room only) and make it feel a bit bigger. I know it sounds complicated, but is it do-able do you think?
Any advice would be greatly appreciated! Many thanks
