Roofer insists warm-deck roof needs an air-gap... is he right, does it matter?
9 Jan 2020
We plan to replace the top deck on a warm-roof project. It is a standard setup currently T&G lower deck -> VPL -> PIR -> 18mm ply -> shingles and the ply will be re-laid with OSB and EPDM used so the new roof will retain the PIR and be virtually the same except using EPDM as the weatherproof layer.
We are torn between self-install (with help) or using a roofer but one roofer is adament we need an air-gap between the PIR and top-deck OSB - his quote includes battening with thin (10-20mm) lathes between PIR and OSB.
I am fairly sure this isn't needed and I heard his other partner debating with him on it (but he's the gaffer and insists) but he's well-respected and very experienced. Realistically, would doing it his way cause any problem? Is there a benefit? If it makes no real odds I am not going to argue "because I watched a YouTube video" but if it's a bad thing to do, I would perhaps pick someone else if he's totally insistent doing this.
It can't harm - there are such things as hybrid roofs - but if the the vapour barrier does its job there shouldn't be a problem with condensation getting through to the deck and so no need for ventilation that a cold roof has.
Blup
A warm roof absolutely does not need ventilation, as for benefit, the benefit is all for the roofer to charge you extra for something unecessay, he would also have to fit vents either side of the roof, at your additional expense.
