My daughter has just moved house recently and her new abode has full gas central heating (it’s not a combi boiler) with a standard copper hot water tank in the airing-cupboard.
All the radiators have new TRVs fitted including the large lounge which has 2 radiators.
However the lounge has a separate temperature control that is wall-mounted, well away from either radiator. There are no other wall mounted temperature controls anywhere in the house.
What will be the function of this wall mounted unit?
Will it just control the temperature in the lounge area by restricting the hot water to the 2 radiators in that room or will it over-ride everything and control the boiler directly?...........which would be odd???
If it does just control the lounge temperature surely it is in conflict with the TRVs ???
Is it best to switch the lounge TRVs to the highest setting and let the wall mounted unit control the room temperature or vice-versa?
Confused.
All replies gratefully received.
Confused.
