Hello, I have a ongoing problem that's really annoying and no matter what I try I don't seem to be able to rectify.
I have a remeha boiler and a remeha celcia 20 thermostat in my living room which is about a meter from the radiator. I normally set the thermostat to 20-21 degrees and leave on constant rather than timer. What I tend to notice is even when the room has hit 20-21 degrees ( in some instances 25) the LCD display shows the radiator symbol and you can here the boiler fire up.
I know the room can't be exact temp as heat still radiates after boiler has stopped. What I can't understand us why it fires up again When its already past required temp. It gets really hot sometimes. So much so that I end up turning it off. With winter approaching I'm worried about the fule bill if indeed there is a fault.
I had left it on today while at work. At 16 degrees. When I came in i could here the boiler running, I pushed the info button on the thermostat and it said current room temp was 21. I don't get it
