I recently had my room thermostat removed from the wall in order to plaster underneath it, and when it was replaced, found that the central heating programmer was completely dead.
On calling the gas man out, he replaced the programmer which promptly blew again straight away.
He investigated further and then took the room thermostat off the wall, said it had been incorrectly wired when replaced and this had caused both the old and new programmers to blow fuses. He replaced the room thermostat, wired it up properly and then replaced the fuse in the new programmer and everything now works fine.
My question is, is it possible that the room thermostat being incorrectly wired back would have caused the programmer to break?
If not, are there any other possibilties? If the programmer was fine before the thermostat was removed and broken after it was replaced, then surely the two must be related?? Both programmer and thermostat were Honeywell.
Many thanks for any help - much appreciated!
