Room Thermostat will not start combi boiler to heat radiator
17 Feb 2003
The down stairs thermostat will not start the combi boiler to heat the radiators.
I swapped the thermostat from upstairs that will start the boiler with the downstairs one but still no luck.
If i turn it on upstairs it will only do upstairs but if i change the settings on the motorised control valve it will do upstairs and downstairs but the system pressure becomes very high and unstable.
Do you think it is a wiring fault or a motorised valve fault? :cry:
I am not a plumber or heating engineer.
unless you have changed or touched anything i should say its a motorised valve fault, they do seem to go wrong and get "stuck" often
