Room thermostat
29 Dec 2006
Hampshire
hi does any one know what the conntact breaker gap should be set to on a wall room thermostat mine is on the lounge wall and when i was wallpapering i unscrewed the wrong screw and the gap moved . the thermostat is a scatchwell . thankyou for any help .
about 1mm should do it... But if your decorating why not spend £12 and get a nice new one... Satchwell still make stats but honewell look nicer.. You will have 4 wires in there and they SHOULD be blue = neutral red = live in yellow = live out and the earth wire which may be bare or sheathed in yellow /green...
thanks for your reply i was going to buy a new one but can i get the same one so i can do a swop with the wiring ?
If its an old stat as u stated with a contacter gap it may only have red & black wire in it live in & live out. Either way there easy to swap only if u do only have 2 wires the new stat will have to be mechanical as well as the electronic type wont work with out a neutral.
guess again.
mine does (and no i didnt alter it, its meant to work with just live and switched live
OH i'l stand to be corrected. what make of electronic stat did u buy that works without a neutral conection Breezer ?????? the only type i know of are the battery type.
I have opened the gap to0.50mm i dont think it was 1mm before as this would mean undoing the nut and i only undone the screw that goes into an elongated slot . it is not working properly so i think i may need a new one ?
hi i have brought a honeywell T6360B to replace my satchwell tlx2259
satchell = 6 (2.5) a 220-240 it has 3 wires red. bl;ue. yellow. no earth ?. The new honeywell has 5 connections earth. 2.3. 4. 1. i have been on the phone to honeywell technical and the lady there says the live goes to 1 (so red to 1 ? ) she said switch live goes to 3 and neutral to 2 . is the blue the neutral or the yellow ? thanks for any help
