Hello all,
Maybe you can give me your experience or ideally reference to some text on this one?
I'm in the middle of a re-wire of a domestic property. The property was stripped back to brick, and it is to be letted and so naturally part M's guidance of accessory heights has been considered.
All switches and sockets have been installed within the 450mm-1200mm barrier, with exception of fan isolator switches as they're not for operational use of course.
The plumb originally was gonna use a wireless stat, but the client then asked for one to be wired. So my guy on site put the three core he requested from the boiler to the position that was pointed out, but then lowered it to the 1200mm height.
Now the plumber is saying that it should be raised so that it will properly pick up the warmer air for an accurate operation, and my guy says that it's a thermostat that will have to be operated by the tenant for general use and would need to be considered under part M like everything else.
Now I find myself agreeing with both of these arguments
I have looked through part M for either an exception or inclusion of such and have had no luck. The electricians guide doesn't seem to have helped me either.
Can someone point me in the right direction please, I would like to find a piece of text that I could use to back up whatever decision is needed.
I'm off out for a few hours now and so can't reply till later, but thanks for any help
widdler
widdler
