Hi guys
This is my first post, so be kind
I have a brick-built flat roofed detached garage in my back garden. Its about 18ft by 18ft. Its roof is made up from 9 by 2 inch rafters slung across the gap, with boards nailed on top, and felted. On the outside, there is a fascia board (plywood) nailed all around the edge of the roofing. The actual roof was re-felted about 2 years ago by my house's previous owner.
I noticed the other day that the paint on the fascia board had started peeling. Further inspection revealed that it was rotten through. Even worse, when I removed it the joist it was directly nailed to is rotten in the middle at the bottom for about 6 feet of its length at about 2-2.5 inches in height.
So what is best? Do I have to remove the joist completely, or will cutting out the worst (this 6 foot by 2 inch by 2 inch section) and replacing it be enough? I have some wood hardener, wet rot treatment & preserver. Is this adequate to treat the surrounding area if I do not completely replace the joist ?
We plan to convert the garage into a games room in the coming months. With this in mind, I have thought of getting a local roofing contractor to look at the roof. However, I expect them to say that I have to replace it so they could get some work out of it
I suppose that a portion of the roof would be have to be stripped back so they could replace the joist. Does anyone have any idea of this cost? I am in Nottingham.
Thanks in advance
Thanks in advance
