Hey Rouhcaster,
It appears to me that you may be the person to help me out!
Over the past couple of years, I've pretty much had my whole house re-plastered. This has involved two unassociated "professionals" on seperate occasions and myself. (due to costs and time I've had to do alot of the work!)
I think I have the same problem as Rocky62, Chicken wire cracking, or as you call it, spider web cracking. It was first noticed in the dining room, which is the only room that was dot-and-dabbed, and we initially thought the boards hadn't been scrimmed over the joints. But now I've noticed that these hairline cracks are appearing everywhere!!
From what I remember, there weren't any cracks in the old plaster at all, so I guess that counts out pre existin cracks opening up again? The plaster doesn't seem hollow at all, apart from the odd small patch here and there!
Is there any reason why I can't just painstakingly fill these cracks and redecorate, or has it got to be removed end re-skimmed? If removal and skimming is necessary, how would it be best to prep the walls to ensure this problem is not repeated?
Thanks in advance!
Thanks in advance!
