Whilst decorating i decided to sink a double plug socket into the wall, when i removed the socket cover i have found that the socket which is a spur from another in the room has been connected to the main socket using some white round cable which has brown blue and yellow/green wires,( it is similar to the cable used on electrical appliances only a bit thicker ) Should i change it or is this cable ok to use.
