I tried to use a router sled (with a bowl shaped router bit) to plane/thickness some pieces of timber salvaged from some pallets (I saw a cool project I wanted to emulate but without buying a thicknesser). The problem is that I would "plane" (can I call it that?) one side of the board and then flip it over and do the other side. The result was never a perfect (not even approaching usable) board. I've tried to illustrate the results with an exaggerated sketch:
Any idea why this is happening? It's not like the router sled sags in the middle; in that direction the cross-section is fine. Do I need to use a hot-glue gun to keep the board still/flat? Until now, I've been using a couple of wedge-shaped particle board pieces that I tap against with a hammer.
