I'm trying to fit a new plug above a worksurface in my kitchen on an internal partition wall. I have cut out for the plastic mounting box, and now I need to get the cable down 3 ft to get under the floorboards. The problem is that the wall seems to be made of a plasterboard sandwich with a lattice of cardboard running horizontally and vertically inside. There are holes running horizontally and vertically in the middle of each cell for wires, but since the flat is 40-odd years old, it is only big enough for the single core cable which my lighting circuit used to be wired in (until I rewired it). Can anyone suggest a way of getting 2.5 T+E * 2 down there?
I've tried ramming a chisel down it, but the hole is too awkward to work in, and I don't have any plumbing rods or similar to try to push a path through. Is the only other way to cut a channel, push the wire in and then replaster? Also should I be using conduit of any kind?
