- Joined
- 11 Aug 2024
- Messages
- 9
- Reaction score
- 0
- Country
I need to run some cables* from a loft space, down via a stud wall to under the floorboards that make up the first floor.
If the stud wall is sitting on top of a joist running in the same direction, how do you route the cables into the stud wall below? I figure the stud wall will likely be wider than the joist, but if its centred on the joist there won't be much room either side for drilling?
*This is for network cables but of the available topics this seemed to be the most relevant - apologies if its in the wrong place
