I tried to route the edges on some 16mm chipboard (loft boarding) panels so there was 4 lengths of 4 foot to do.
After 1 length it was taking longer and I examined the bit (which came free with the router) and it had burn marks and the cutting edge was worn (visibly)
I'm guessing the (cheap) router bits are HSS? Surely this should be upto the job of routing chipboard?
What's gone wrong? I was feeding the router against the pressure of the bit (I was only taking a thinish slice off the end of the boards) I think there is an arrow on the router as well which I assume is the direction you are supposed to move the router?
The bit is about 10-12mm diameter and router speed was on maximum - was it just too fast?
