I currently have an island unit containing an electric hob. This will shortly be unused and a gas hob elec oven installed against the wall (freestanding).
The socket for the hob is in the island and fed from under the floor. The gas cooker will require an elec feed and I intend to use the same feed as the current one, it has to be resited and will be about 5 feet shorter than the island, however I understand it will have to be wall mounted and then a feed from that socket to the freestanding cooker.
I am not doing the electrics even though it should be a simple connection but I intend to get the basics ready for the elec, ie the route to the new location.
So if the cable comes from under the floor and mounted say 3 feet up the wall does this cable get fed through the cavity in the wall OR do I hack off the tiles and gouge out a channel in the wall for the cable and then refill/tile afterwards.
The gas fitter will bring his elec on the day so I need to have any `building` work already done.
Thanks, hope it makes sense.
