Currently I have both my electricity meter and consumer unit sitting side by side in the garage. I am about to have the electricity meter moved outside (directly behind where it currently is). This will mean that I will need to run the meter tails through a cavity wall. The offset between the meter and the consumer unit is around 3 feet. Can I simply run the meter tails (25mm double insulated) through the cavity (without conduit), or is this forbidden?
