I have just removed some 'flex' cable from 2 outside lights that were (obviously) incorrectly fitted by the previous owner. The flex ran around the outside walls and through a hole to a switch near to the consumer unit. I will be replacing the wiring with 1.5 twin and earth and will reduce the amount of wiring running around the outside walls by going through the walls into the ceiling void. However, I will still need a short vertical run to get to the required height. So my question is, is there any regs I should be aware of routing the cable outside? Does it need protecting? Should I be using any particular type of cable? Incidentally I will be allowing a small loop to avoid water running to the light fitting.
Thanks in advance for any advice.....
