Rrender mix.
7 Jan 2005
I wish to render the outside wall of my house. Can anyone tell me what the best sand/cement ratio mix I should use, both on first and second coat. And also what is the best sand I should use.
5:1 should be fine ask for plastering sand the builders merchants will know what you meen its a mixture of soft builders sand and fine sharp sand, some merchants sell it as mixed building sand.
Don't forget to add some plasticiser/retarder to the mix.
Can you please tell me, is the scratch coat mix ratio the same as the top coat. It's just that I once heard someone say they have to be different to avoid cracking later.
ratios for rendering (trust me ime a plasterer)
backing or scratch coat 4:1 (add a plasticiser to the water)
finishing coat 5:1 (add a waterproofer and plasticiser mix to water)
make sure you ask for plastering sand
